No SPDIF sound output option possible since I use windows 11
Dwayne Beekman 0 Reputation points
2025-12-09T19:09:28.0266667+00:00
Issue: No sound to speakers since recently upgrading to Windows 11
Setup:
Dell Precision 5540 I9 laptop;
Dell WD19TB 210 ARJD Thunderbolt Docking station;
Logilink UA0099 7.1 usb soundbox;
Sonos speaker setup with Ray soundbar, Sub mini and 2x One SL
Speakers are connected with an optical sound cable to the usb soundbox and soundbox is connected to the dockingstation with usb. This setup worked fine for years with Windows 10 and now since I use Windows 11 I can not use the ''SPDIF'' output from the soundbox anymore. Windows says its not connected while nothing has changed to the setup and all cables are still connected.
I hope someone can help me sorting this out ? I am out of ideas. Already checked all sound settings en updated drivers etc. etc.
Regards,
Dwayne
Windows for home | Windows 11 | Settings
    2025-12-09T19:09:48.0066667+00:00
    It sounds like you're experiencing issues with your SPDIF output after upgrading to Windows 11. Here are some steps you can take to troubleshoot the problem:
    1. Check Sound Settings: Right-click the sound icon in the taskbar and select "Sounds". Under the "Playback" tab, ensure that your USB soundbox is set as the default device. If it’s not listed, right-click and check if "Show Disabled Devices" is enabled.
    2. Update Drivers: Since you mentioned that you've updated drivers, ensure that you have the latest drivers for your USB soundbox and the Thunderbolt Docking station. You can check for updates via Windows Update or the manufacturer's website.
    3. Reinstall USB Soundbox: Unplug the USB soundbox, restart your computer, and then plug it back in. This can sometimes reset the connection and allow Windows to recognize the device properly.
    4. Check for Windows Updates: Make sure your Windows 11 is fully updated. Sometimes, issues with hardware compatibility can be resolved through system updates.
    5. Use Windows Troubleshooter: Go to Settings > System > Sound, and under "Advanced", select "Troubleshoot". This can help identify and fix issues with audio devices.
    6. Registry Check: If you are comfortable with it, check the registry settings related to audio devices. However, be cautious and back up the registry before making any changes.
    If the issue persists, it may be worth reaching out to the manufacturer of the USB soundbox or checking forums for similar issues related to Windows 11 compatibility.
    References:
  2. Rez 13,000 Reputation points Independent Advisor
    2025-12-09T19:50:07.3466667+00:00
    Hi Dwayne, I get how confusing this can be when everything worked fine before. The main reason SPDIF isn’t showing as connected in Windows 11 is usually driver compatibility. Windows 11 changed how it handles digital audio outputs, and older USB soundbox drivers often don’t fully support the new system. Let’s start simple: can you check if SPDIF is listed under Playback devices when you right-click the speaker icon and enable “Show Disabled Devices”? If it’s there, try enabling it. If not, the next step is reinstalling or updating the Logilink UA0099 driver from their support page, or even removing it in Device Manager and reconnecting the soundbox. Also, have you noticed if any recent Windows updates were installed right before this started? That could help us decide if rolling back or applying a patch might fix it.
    Regards,
    Rez
  3. Dwayne Beekman 0 Reputation points
    2025-12-11T19:55:14.9366667+00:00
    Hello Rez, thanks for your fast reply !
    • Its not listed in playback devices and I can not add or enable it;
    • I have got the most recent driver from the Logilink website;
    • Removed it in device manager and reinstalled it, changed nothing.
    It started since I did the update from Windows 10 to 11, now 11 already had a lot of updates since I am unsing it but all the updates changed nothing for my sound problem.
    Hope we can come to a solution for this.
    Regards,
    Dwayne
  4. JosephT71 8,855 Reputation points
    2025-12-11T20:46:34.2666667+00:00
    Microsoft took out ac3 codec in windows 11. No dolby digital means spdif is restricted to 2 channel pcm audio.
    https://support.microsoft.com/en-us/windows/codecs-in-media-player-d5c2cdcd-83a2-4805-abb0-c6888138e456
  5. Rez 13,000 Reputation points Independent Advisor
    2025-12-11T20:53:55.3533333+00:00
    Thanks for sharing those details, that helps narrow things down. Since SPDIF isn’t showing at all and you’ve already reinstalled the latest driver, this points to a deeper compatibility issue between Windows 11 and the UA0099 chipset. Windows 11 changed how it handles digital outputs, and some older USB sound devices don’t fully register SPDIF anymore, which confirms Joseph's response above. That SPDIF codecs specifically the ac3 has been removed.
    A couple of things we can still try:
    First, download the ac3 codec with a guide here. (DISCLAIMER: This is a non MSFT website, please perform the steps with caution)https://www.neowin.net/guides/how-to-restore-dolby-digital-ac-3-support-in-windows-11-24h2/
    Second, can you confirm if the device shows up in Device Manager under “Sound, video and game controllers” and if its properties mention SPDIF or digital output? If it does, we might be able to force-enable it through advanced settings. If not, the OS isn’t detecting that capability at all, which usually means the driver isn’t exposing it.
    Lastly , trying with a generic USB driver and see if the codec will appear with the driver.
