Same Issue, there is no (Right Alt+Shift) option
Issue with Right Alt + Shift Not Switching Languages Properly in Windows
Hello,
I am experiencing an issue in Windows with the keyboard shortcut Right Alt + Shift used for switching input languages. The shortcut works only when switching from English to Arabic, but it does not work when switching from Arabic back to English. Meanwhile, the Left Alt + Shift shortcut works normally in both directions.
I have already tried the following troubleshooting steps, but the problem persists:
Adjusting the Advanced Keyboard Settings.
Removing and re-adding the input languages.
Resetting the Input Language Hotkeys.
Testing with an external keyboard – the issue remains the same.
Running settings/tools as Administrator.
Fully updating the Windows system.
Despite all of this, Right Alt + Shift still does not work when switching from Arabic to English.
Please assist in resolving this issue, as it significantly affects my workflow and typing speed. Kindly advise if there is an update or specific configuration that can fix this problem.
Thank you.
Windows for home | Windows 11 | Settings
Abdulaziz Alhurr 15 Reputation points
2025-12-14T11:04:36.16+00:00 Guys, I had the same issue, and it's super frustrating. Here's a fix that worked for me:
Press Win + R, type regedit, press Enter Go to:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard LayoutIn the right panel:
If Scancode Map exists, double-click it
If not, right-click → New → Binary Value → name it Scancode Map
In Value data, enter the following exactly
00 00 00 00
00 00 00 00
02 00 00 00
38 00 38 E0
00 00 00 00
It should look like this at the end:
Click OK and restart Windows (full reboot). This should resolve the issue.
PC- DABOUR 20 Reputation points
2025-12-09T23:37:36.4233333+00:00 As I said in this post in Arabic, this is the only solution; there is no other solution.
https://quic.hkg1.meaqua.org/en-us
This is the solution, my friend
Download the program:
AutoHotkey.exe
Then use the script I created below. This problem literally made me unable to type properly, so I had to use an external program as a temporary workaround.
1 - :
#NoEnv SendMode Input *RAlt::SendInput {LAlt Down} *RAlt Up::SendInput {LAlt Up}Save this code in a file named:
VolumeControl.ahk
Then right-click the file and choose Run with AutoHotkey.exe
2 - :
shell:startupTo run the script every time Windows starts, place a shortcut of this file in that path.
Noel Macadangdang 8,245 Reputation points Independent Advisor2025-12-05T15:33:53.0233333+00:00 Hi Mohamed,
Thank you for sharing your question. I understand how annoying this language switching thing is when you need it to work fast. Based on what Microsoft says and what others are seeing, I am here to help.
The reason Right Alt + Shift only goes one way (English to Arabic) is a bug in recent Windows updates (like KB5070311 for Windows 11). It's not your fault. Left Alt + Shift still works because the system likes it better. Right Alt (which is like AltGr) can mess with language switching, especially after updates.
Please follow these steps.
Double-Check Your Shortcut Settings
Head to Settings > Time & Language > Typing > Advanced keyboard settings.
Click Input language hotkeys → Change Key Sequence.
Make sure both Left and Right Alt + Shift are turned on for switching languages. Turn them back on if they aren't.
Use a Different Shortcut for Now
Try using Win + Spacebar to switch languages. People say it works even when Alt + Shift doesn't.
Look for Bad Updates
If this started after you updated Windows, get rid of the update that's causing trouble:
Go to Settings > Windows Update > Update history > Uninstall updates.
I hope this helps.
Best Regards,
Noel
Mohammad Zaatra 0 Reputation points
2025-12-14T10:07:23.39+00:00 Same issue within my company here
Right Alt+Shift only moves languages to the right and doesnt keep switching
This only happened after the latest update
Looking for a fix that i can deploy to my company desktops
