How do I get a replacement power cord for the Microsoft Surface Studio 1
Paul Mazzara 20 Reputation points
2025-10-20T19:40:50.26+00:00
I cannot locate my power cord for my Surface Studio with 28" screen. It's a three prong female that fits into the back of the unit and the other end into an electrical outlet.
Surface | Surface Studio | Power and battery
Answer accepted by question author
  1. Edward Schlobohm01 9,795 Reputation points Independent Advisor
    2025-10-21T14:10:10.6066667+00:00
    Hi,
    Thanks for getting back. Please visit this article as this is similar with your concern and this is helpful; here is the link: https://quic.hkg1.meaqua.org/en-us/answers/questions/2336355/i-need-a-replacement-power-cord-for-the-surface-st
    Hope this helps,
    Regards,
    Edward
1 additional answer
    2025-10-20T20:55:06.47+00:00
    Hi,
    Thanks for reaching out to the Microsoft community. I understand that you need to replace your Surface studio power cord. Please allow me to provide some option on how to do this,
    I highly suggest that you visit the help article here "How to replace your Microsoft PC Accessory under warranty page here: https://support.microsoft.com/en-us/surface/how-to-replace-your-microsoft-pc-accessory-under-warranty-65402955-b97d-480c-93b4-de1defa89562
    just follow the instructions or you may visit the Microsoft official store for more information and option for replacement here: https://www.microsoft.com/en-us/surface/buy?ocid=cmmjcz28if8
    Look for the 3-prong female connector that fits into the back of the Surface Studio.
    Wattage: Surface Studio 1 typically uses a 127W power supply, for guaranteed compatibility please visit this link, " Surface charging requirements and power supplies"
    https://support.microsoft.com/en-us/surface/surface-charging-requirements-and-power-supplies-0d9d51d4-594b-464d-9086-c90f35b80c01
    Hope this helps,
    Regards,
    Edward
