HAVING PROBLEM WITH BLUETOOTH SPEAKER KEEPS CONNECTING AND DISCONNECTING WHEN NO SOUND IS PLAYING IN LAPTOP
Zaid Usmani 0 Reputation points
2025-10-20T06:10:48.9233333+00:00
HELLO, I AM HAVING PROBLEM WITH MY BLUETOOTH SPEAKER WHICH KEEPS CONNECTING AND DISCONNECTING WHEN NO SOUND IS PLAYING IN MY LENOVO LOQ LAPTOP ALTHOUGH THE SPEAKER WORKS ALRIGHT WITH OTHER DEVICES AND ALSO MY LAPTOP WORKS WELL WITH OTHER BLUETOTH DEVICES. IT ONLY HAPPENS WHEN BOTH ARE PAIRED TO EACH OTHER? I HAVE ALREADY
UPDATED MY WINDOWS DRIVER
Windows for home | Other | Devices and drivers
  1. Randy Baroja 19,200 Reputation points Independent Advisor
    2025-10-20T11:33:54.7733333+00:00
    Hi,
    You can try these steps to fix your Bluetooth speaker repeatedly connecting and disconnecting on your Lenovo laptop. First, disable power-saving for the Bluetooth adapter by going to Device Manager, selecting Bluetooth, opening your adapter’s Properties, then Power Management, and unchecking 'Allow the computer to turn off this device to save power," which prevents Windows from dropping the connection when idle. Second, forget and re-pair the speaker to reset the connection and resolve any handshake or profile issues. Third, set the speaker as the default playback device in Sound Settings so the system keeps it active even when no audio is playing.
    When this happens, if you start playing a YouTube video or some music, does the speaker reconnect right away and work normally, or does it stay disconnected for a bit?
    Kind regards,
  2. Jeff White 0 Reputation points
    2025-12-11T21:24:44.8233333+00:00
    For Dell, I found these instructions. https://www.dell.com/support/kbdoc/en-us/000122996/bluetooth-mouse-losing-connection-or-connectivity-issue?msockid=11af3873145a6cfe1b292c7615a16d17
    The Power Management tab was under the Intel(R) Wireless Bluetooth entry.
    Don't know yet if this fixes the problem.
