how to fix default audio in my pc
Ganesh Stn 0 Reputation points
2025-09-06T08:05:58.6466667+00:00
my laptop audio not working and icon also shown as X mark
Windows for home | Previous Windows versions | Devices and drivers
  1. Kapil Arya 36,471 Reputation points Volunteer Moderator
    2025-09-06T09:21:31.3333333+00:00
    Open Device Manager, check if you've audio driver installed.
    Try updating audio drivers to latest version.
    Or if you've already updated them, try to roll back previous version to see if that works.
    Run Playing Audio troubleshooter from Settings app > System > Troubleshoot > Other troubleshooters. Let us know what it reports back.
  2. hidaka 53,826 Reputation points MVP Volunteer Moderator
    2025-09-08T16:15:27.5533333+00:00
    Your laptop may be experiencing a fatal malfunction. If a clean reinstall of Windows does not restore audio, have it repaired by the manufacturer or purchase an alternative USB audio device.
