no audio device installed problem in my pc please solve
2025-05-05T03:10:08+00:00
Please solve my this problem
Microsoft Edge | Install and update | Previous Windows versions
  1. Lester Bernard Reyes 68,210 Reputation points Independent Advisor
    2025-05-05T03:49:25+00:00
    Hi Ali, thanks for reaching out. My name is Bernard, a Windows fan like you. I'll be happy to help you out today, my timezone is UTC +8.
    I understand the issue you have, there is nothing to worry I am here to assist. Was it working fine before? Or is there no audio at all? Are you using a laptop or a desktop? If you are using a desktop, kindly check if there is a speaker installed on the PC, Moreover, if it's working fine before, kindly follow the steps below:
    Method 1. Run Audio troubleshooter:
    Press the Windows Key + R, then type in:
    msdt.exe /id AudioPlaybackDiagnostic
    Then hit OK and follow the prompt to run the Audio troubleshooter.
    Method 2. Roll Back Audio driver:
    -Press the Windows key + X
    -Go to Device Manager
    -Expand the Sound, video and game controller
    -Look for Realtek (R) Audio or High Definition audio
    -Right-click and click "Update Driver"
    -Look for "Browse my computer for driver"
    -Click "Let me pick drivers available drivers on my computer"
    -Choose an old driver or other name of driver then select it and hit next until it installs.
    Note: If the issue persists, please download and install an Audio driver from your manufacturer's website.
    Let me know how it goes and I hope that helps.
    Bernard
