How to do Low Level Design for Given HLD in Azure
Relay 320 Reputation points
2025-05-18T03:57:50.1766667+00:00
I have created a High level design where I am consuming JSON file from Azure Stream Analytics to Azure SQL.
What all are properties I should consider for creating Low Level Design for same.
ASA-ASQL-LLD
Please help me with your expertise knowledge.
Thanks a lot
An Azure real-time analytics service designed for mission-critical workloads.
Answer accepted by question author
  1. David Broggy 6,776 Reputation points MVP Volunteer Moderator
    2025-05-18T06:27:27.7366667+00:00
    Hi there,
    Here are some low level consideration for your stream analytics architecture:
    Low Level Design: Azure Stream Analytics to SQL Integration
      1. Data Source & Input Configuration
      - Input Type: JSON data from Azure Stream Analytics
      - Serialization Format: JSON (configure compression if needed)
      - Partition Key: Identify a field in your JSON for partition optimization
      - Timestamp Policy: Choose between arrival time or event time (application timestamp)
      - Backfill Option: Configure if historical data processing is needed
      - Input Validation: Enable to verify schema compliance and improve resiliency
      2. JSON Schema Definition
      - Schema Inference: Decide between automatic or explicit schema definition
      - CREATE TABLE: Define explicit schema for reliable processing using ASA's CREATE TABLE
      - Data Types: Map JSON types to appropriate SQL types (string → nvarchar, numeric → decimal/int)
      - Complex Types: Handle nested objects and arrays with proper extraction functions
      - Default Values: Set default values for missing fields if needed
      3. Stream Analytics Query Design
      - Query Optimization: Structure query for efficient processing
      - Temporal Windows: Define tumbling/sliding/hopping windows if aggregation is needed
      - Functions: Implement UDFs for complex transformations if required
      - Error Handling: Use TRY_CAST functions to prevent job failures
      - Partition Hints: Leverage PARTITION BY for parallelism
      - Reference Data: Include reference data joins if required for enrichment
      4. SQL Database Output Configuration
      - Table Design:
        - Primary Key constraints
        - Clustered/Non-clustered indexes on frequently queried columns
        - Appropriate column data types matching ASA output
        - Partitioning scheme if high volume
        - Compression settings for large tables
      - Batch Settings:
        - Max batch count (recommended: 10,000 for optimal performance)
        - Batch size (recommended: 1-2 MB)
      - Authentication: Use Managed Identity for secure connection
      - Retry Policy: Configure appropriate retry settings
      - Column Mapping: Define explicit column mapping if field names differ
      5. Performance Optimization
      - Streaming Units (SUs): Allocate appropriate SUs (start with at least 6 SUs for production)
      - Partitioning Strategy:
        - Enable "Inherit Partitioning" option for parallelism
        - Ensure balanced partitioning to avoid hotspots
      - SQL Database Tier: Select appropriate service tier (Premium/Business Critical for high throughput)
      - SQL Indexing Strategy: Implement proper indices on frequently queried columns
      - Compatibility Level: Use latest ASA compatibility level for best performance
      - Watermark Delay: Monitor and optimize to maintain processing speed
      6. Monitoring & Alerting
      - Key Metrics to Monitor:
        - Watermark delay (target <10 seconds for real-time processing)
        - SU utilization (target <80%)
        - Input/Output events rate
        - Runtime errors
        - Failed function calls
        - Resource utilization
      - Alert Thresholds:
        - Watermark delay > 1 minute
        - SU utilization > 80% for 15+ minutes
        - Runtime errors > 0
        - Input events with deserialization errors
      - Logging Configuration:
        - Enable diagnostic logs
        - Set up Log Analytics workspace
        - Configure proper retention period
      7. Error Handling & Data Quality
      - Input Data Validation: Implement schema validation at input
      - Dead-letter Path: Configure for invalid/unprocessable events
      - Error Handling Strategy:
        - DROP errors: Discard invalid records
        - RETRY: For transient failures
        - Exception path for detailed troubleshooting
      - Data Quality Checks:
        - Implement checksum validation if applicable
        - Set up data quality monitoring dashboards
      8. Security & Compliance
      - Data Encryption: Enable encryption at rest and in transit
      - Secure Authentication:
        - Use Azure Active Directory (AAD) and Managed Identity
        - Avoid shared credentials/connection strings
      - Network Security:
        - Implement Private Endpoints or Service Endpoints
        - Configure firewall rules appropriately
      - Auditing: Enable SQL auditing for compliance requirements
      - Access Control: Implement proper RBAC for both ASA and SQL
      9. Disaster Recovery & Business Continuity
      - Geo-replication: Set up SQL geo-replication if needed
      - Backup Strategy: Configure SQL automated backups
      - Job Recovery Plan: Document steps for job recovery
      - Configuration Versioning: Store job definitions in source control
      - Failover Testing: Regularly test failover scenarios
      10. Deployment & DevOps
      - CI/CD Pipeline: Implement automated deployment
      - Environment Promotion: Dev → Test → Prod strategy
      - ARM Templates/Bicep: Infrastructure as code for reproducibility
      - Feature Flags: For controlled rollout of changes
      - Blue-Green Deployment: For zero-downtime updates
      11. Cost Optimization
      - Right-sizing: Adjust SUs based on actual load patterns
      - SQL Resource Optimization: Implement elastic pools if applicable
      - Data Lifecycle Management: Configure data retention/archiving
      - Scheduled Scaling: Implement scheduled scaling for predictable workloads
      - Cost Monitoring: Set up cost alerts and regular reviews
      12. Documentation & Governance
      - Data Dictionary: Document all fields and their mappings
      - SLA Definitions: Define performance and availability SLAs
      - Runbook: Create operational procedures for common issues
      - Change Management: Establish change control processes
      - Knowledge Transfer: Ensure team training on the solution
    References:
    https://quic.hkg1.meaqua.org/en-us/azure/stream-analytics/
    https://quic.hkg1.meaqua.org/en-us/stream-analytics-query/stream-analytics-query-language-reference
    1 person found this answer helpful.
0 additional answers
